PULSE empowers project managers to keep their projects on track, align with sustainability goals, and deliver impactful results.
Key Features of PULSE
- Project Dashboard: With PULSE, project managers can visualize the entire project at a glance. The dashboard offers a clear overview of key project details such as SDG impact, targets, impact indicators, finances, and carbon (for carbon offset and climate impact projects). Whether you're managing a social project or a carbon offset initiative, PULSE provides essential insights to keep your project on course.
- Add Implementers & Project Details: PULSE enables clients to seamlessly onboard project implementers, add key project details, and outline specific goals.
- Track SDG Impact: For projects focused on sustainability, PULSE helps you track contributions to the Sustainable Development Goals (SDGs). Whether you're measuring beneficiary impact or carbon offsets, PULSE keeps you on target and helps showcase the positive influence of your project.
- Distribution & Monitoring Integration: PULSE integrates seamlessly with Regenfi.tech's CONNECT and TRACE modules, allowing users to track distribution efforts and monitor project performance in real time. These modules are used by the implementation teams and the data is fetched to PULSE in real time.
- Financial Management: PULSE gives clients the ability to manage project finances by comparing planned versus actual spending. You can easily track where your budget is going, identify overspending or underspending, and ensure financial accountability
- Lifecycle Tracking: Keep your project moving forward with PULSE’s lifecycle management feature. It helps you monitor which milestones and tasks have been achieved, highlights areas of delay, and provides visibility into the overall progress of the project.
- Carbon Inventory Management: For climate action projects, PULSE allows you to track carbon inventories, measure them against your company’s emissions, and identify surplus carbon for future planning. It ensures you stay on top of your carbon commitments while highlighting the years where action may be required.
Simplifying Project Management for Impact
At Regenfi.tech, we understand that managing a project’s lifecycle requires coordination, accountability, and efficiency. PULSE simplifies these processes by providing a robust tool that tracks every aspect of your project.
